Ir para o conteúdo principal
Bose AV35 Control Console stuck on blinking green light
I have a Bose AV35 control console which is stuck on green blinking light.
The green blinking light mean the system is starting, but the light doesn't turns to solid green ever.
Other observation is No output to display or to sub-woofer module.
I tried resetting the system no luck.
Any one know whats happening in there. . . . .
Esta é uma boa pergunta?
Pontuação 2
1 comentário
How do ou replace the battery in the QC 35? Bose will not do it and I paid $350 for it 1.5 years later battery dies too quick. Any help please.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
It happened to me. It was an issue with the main board due to over voltage via HDMI port. Authorized repair center tried to change the board but after connecting HDMI cable board failed again. Maybe another issue but final diagnosis was "no repair possible" I had to purchase a used control console in ebay.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Varun Gargi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 31
Duração total: 2,624
