Vizio model #E420iAO Tv won't turn on
The power button will only lights the power light on the tv for a few seconds then it goes out.
Esta é uma boa pergunta?
@arth sounds like a bad power board. Could be as simple as bad capacitors. You also want to go ahead and check this video to see if you have the proper voltages. Also check on here since the power board should be similar.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 11
Duração total: 13,849
1 comentário
@arth take a look at your power board. Check the capacitors and the fuses with a multimeter. Post some images of your boards with your question so that we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that.
por oldturkey03
