Ir para o conteúdo principal
Rockchip Quad-Core RK3288C Processor, 11.6" 16:9 HD (1366x768), 16GB eMMC, Integrated Rockchip® Mali T764, LPDDR3 MHz SDRAM, OnBoard Memory 2 GB / 4 GB
18 Perguntas Visualizar todos
It turns on OK but the screen remains white.
The laptop turns on as normal but the screen is white and I am unable to do anything with it. If you tilt it, you can see that the left half of the screen has very light blue vertical lines, in different shades / sizes and patterns. My dog 'may' have stepped on the closed lap tap. Could the pressure from the dog damage the screen???
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hey tinazinger,
Yes, It doesn't take much pressure. They usually crack under the black tape that surrounds the actual LCD. They run around $40-$50 on amazon and pretty easy to change. Get the number off the back of the original LCD before ordering to insure that you get the correct one.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
tinazinger será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 810
