Ir para o conteúdo principal
horizontal and verical white lines on screen
I did housing my iphone6 for several times. Yesturday, I saw one horizontal line after closing my phone, touch not working just on the line. Opened and reconnect to fix this, but it got worse. After reconnecting several times, touch is not working anywhere. I see no ripping on the cable. Line moves when I open and close the lcd. Is the sensor gone? or can I fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Make sure you have the digitizer cable firmly seated and that it is clear of any dust. I would also try using an alcohol wipe to clean the contacts. Since their is a visual problem there is something wrong with LCD, not the touch screen, but since you said they both are having issues you may have an issue with your logic board.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I went to the iphone shop and they tried new lcd and it worked. so i guess the logic board is fine. i tried wiping with water. I guess i try alcohol.
por
Adicionar a sua resposta
JoonYoung Ko será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 2,372
