Ir para o conteúdo principal
apple logo pops up seven seconds and shuts off
Hello all,
Another weird one here. The phone doesnt have water damage and no physical damage. It boots to the apple logo for about 7 seconds and shuts off. Thats all it does. Tried swapping the battery and LCD, which neither of which worked. Tried hard booting, doesnt work either. Any ideas?
thanks!
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Does the iPhone shut off immediately when the phone is at apple logo and plugged in when you unplug it?
por
Hi Ben, Yep, doesnt matter if its plugged into power or computer. Plugging it in triggers it to turn on, 6-7 second apple logo and it powers off.
If I hard boot it, apple logo 6-7 seconds, shuts off, comes back on apple logo for 3-4 seconds and shuts off.
por
Any other tips? Maybe its a chip? Which chip would it be?
por
Adicionar um comentário
4 respostas
Solução escolhida
Try putting the phone into dfu, and restoring to a backup
http://m.youtube.com/watch?v=wlT0vdDRmgE
Esta resposta foi útil?
Pontuação 2
3 comentários:
Does the same thing. It will either shut off after the 6-7 second bright apple logo or it will be stuck on the plug into itunes.
por
Ok. Have you tried plugging it into iTunes?
por
yes, just cycles bright apple logo
por
You noted that it had a hard drop ?? how hard what did i land on ??
you noted that you also tried reloading/restoring from itunes ??
if thats the case it sounds like either board level solder damage and or that drop
could have damage processor or ram>>>
have your tried this
Hold both the home and power buttons at the same time. When the Apple boot logo appears, let go of the power button but continue holding the home button.
Connect your device to your computer and open iTunes. If you don't have a computer, borrow one from a friend or go to an Apple Retail Store or Apple Authorized Service Provider for help.
While your device is connected, force restart it: Press and hold both the Sleep/Wake and Home button for at least 10 seconds, and don't release when you see the Apple logo. Keep holding until you see the recovery mode screen.
When you see the option to Restore or Update, choose Update. iTunes will try to reinstall iOS without erasing your data. Wait while iTunes downloads the software for your device.
If the download takes more than 15 minutes and your device exits recovery mode, you'll need to repeat these steps and choose Restore instead of Update when you get back to this step.
After the Update or Restore completes, set up your device. If you previously backed up your device with iTunes or iCloud and had to restore your device in step 3, you might be able to restore from your backup during setup.
Pontuação 1
1 comentário:
Yes I have attempted to restore it when you plug it into the computer the Apple logo comes up and then shuts off you cannot restore it unless it turns in DFU mode does not work it just continues to only pop up the Apple logo
por
Try to replace the battery ;)
Pontuação 0
1 comentário:
He already tried that.
por
Has it ever had a really hard drop? My cousins friends iPhone was smashed against a wall and even after a screen replacement it still didn't work, showed colored lines across the screen. (Turned out it was a cracked solder joint somewhere)
Pontuação 0
3 comentários:
Yep it took a hard fall. Anyone that repairs board level able to pipe in?
por
Send it to @jessabethany at iPad rehab, she can fix it.
por
Ill bet she could! Id like her input or someone else that has her talent ;)
por
Adicionar a sua resposta
Paul será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 1,997
