Touchscreen unresponsive after fixing power fault
Hi, I had issues where my tablet would not charge, so after you tubing the "supposed" fault, I removed the back cover, and all I done was to disconnect the battery for 15 seconds then reconnect, it then started to charge, however although that solves that issue, now my touchscreen is unresponsive to the touch, it lights up and everything, but that is all, please help?
Esta é uma boa pergunta?
It is possible that the cable for the touch digitizer was accidently disconnected from the main board. I'd check to see if it has become unplugged, even if it doesn't look like it has try disconnecting it and reconnecting it.
por hakugingin
Tried that, disconnected and reconnected securely, still the same
por Terry walker
