Ir para o conteúdo principal
Repair information for the 4th generation iPad. Released November 2, 2012. Model numbers: A1458, A1459, and A1460.
Distorted image after digitizer replacement
My iPad screen cracked and I got a replacement digitizer. Unfortunately after going through the whole process of replacing, I realized that I had left the iPad turned on while replacing the digitizer (i.e. disconnecting and reconnecting LCD, digitizer, and home button). Now, the screen just displays white with a grey line across the screen. I'm positive that everything else still works as it still locks and behaves as expected. Anything I can do before I try to reseat the LCD connectors?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hey there! A grey line across the screen can sometimes be a sign of graphics issues, but the white screen really screams of a poor contact. Unfortunately, I think you'd best crack her back open, after making sure your iPad is off.
Best of luck in your repair!
Esta resposta foi útil?
Pontuação 1
1 comentário:
Hey! I just got around reopening and retightening the cables. I still have a grey line on white background..
por
Your next step is replacing the backlight filter could of been damage during repair since the battery wasn't disconnected during repair. But requires soldering
Pontuação 0
Adicionar a sua resposta
Edric Choi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 182
