Ir para o conteúdo principal
Pergunta encerrada
A1260 - 1 TB hard drive possible?
Dear Sirs,
I have got a question regarding the A1260 Mac Book Pro: Is it be possible to upgrade the hard drive with a 1 TB internal drive? I've currently got a 500 GB drive and am running out of space.
I was thinking (sorry about linking to Amazon...) about the 1 TB Western Digital Scorpio Blue (http://www.amazon.com/Western-Digital-Sc...) but since I have read that this drive is a bit thicker than usual 2,5'' drives I am not sure whether to purchase it or not. Do you have any idea if this might work or are there harsh obstacles?
Thank you very much for you time!
David
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
This is a 12.5 MM drive and will not work in your 15" MBP pre- unibody.
From OWC:
1.0TB WD Scorpio Blue 5200RPM SATA *12.5mm* HD with Advanced Format Technology - Fits all Apple MacBook/MacBook Pro 'Unibody' Models (13/15/17"), MacBook Pro 'pre-unibody' 17", and PC Laptops which support 12.5mm SATA Drives. New with 3yr WD Warranty. (WDGWD10TPVT)
Esta resposta foi útil?
Pontuação 3
2 comentários:
Ok, that's sad. Anyhow, thank you very much for your fast answer!
David
por
David
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,109
