Ir para o conteúdo principal
2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Perguntas Visualizar todos
Hardware test shows error "4SNS/1/40000000: IO0R-1.550"
After the kernel_task process started taking up too much CPU(like 500-1000%) and the system hangs, this happens randomly. I ran the AHT and the error shows up
Figured out this is a sensor issue (SNS) but didn't find any resource mentioning the IO0R code.
Does Anyone know what this code refers to?
PS: My camera is also not working says "No video capture devices were found." in System info
Update (05/20/2016)
I think I found the issue. I opened up my macbook for cleaning up (lot of dust). And disconnected the iSight camera cable. Now the Hardware test passes without any error.
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
sadly apple does not share the information
But SNS is a sensor issue
por
Adicionar um comentário
1 resposta
It's likely a problem with one of your current sensing resistors on the board. These can be replaced. Requires some micro soldering.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks for answer. I thought this was current sensor issue but then I read carefully it says IOzeroR not IzerozeroR. Which seem like I/O port issue or something. I'm just guessing here though.
And if micro soldering solution is not in my reach, would this mean a logic board replacement?
por
Not all the time
you could take it to apple and they will most likely tell you whats wrong and give you a quote
you can use this to your advantage as if its something silly that can be replaced with in 5-10 minutes that you are happy to do then you have saved yourself a bit of money
if it comes to a logic board replacement ( highly doubt) apple charge a fair price but you can get it worked on or buy a replacement and do it yourself
por
Adicionar a sua resposta
goutham será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 10
Duração total: 530
