Why will my printer not pick up paper?
My printer states out of paper even though it is not and will not feed paper for printing?
Esta é uma boa pergunta?
I assume you are trying from the automatic paper tray? Give it a try from the manual paper feed. It's not uncommon for a gear or other mechanical part, that grabs and feeds the paper, to break.
The Epson all-in-one's you find in big box stores tend to be the ones I see go out most -- with one customer, Epson had to replace the same model printer three times in six months under warranty. In each case it was a broken retention spring, inside, on the paper feed.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 216
