My console will not read games
wont read games at all.
only played one song off a cd and then would not play again
Esta é uma boa pergunta?
It sounds like you are suffering from a dirty lens. If the console will boot to the home screen (all the squares and stuff) then you should give a lens cleaning a try. This guide should help you out, although I would use a different lens cleaner than rubbing alcohol. Ronsonol Lighter Fluid or lense cleaner should do the trick.
Good luck, and let us know how it works out.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,571
