Ir para o conteúdo principal
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
Why is my tablet keep turning on and off
It turns on and then off and I can't do nothing with it
Esta é uma boa pergunta?
Pontuação 0
1 comentário
what was done to start the problem ? was it dropped or were you rooting it?
por
Adicionar um comentário
1 resposta
Solução escolhida
If the machine was not damaged either by a drop or you trying to root it you can try disconnecting the battery to clear the cache so it gets a clean boot. Here are instructions to disconnecting the battery
Samsung Galaxy Note 8.0 Battery Replacement
if you just disconnect it for 60 sec it will clear the memory and allow a clean boot .Hope this helps
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Meghan sharp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 264
