Ir para o conteúdo principal
Informações e guias de reparo para modelos de MacBook Pro com telas de 13 polegadas.
9741 Perguntas Visualizar todos
Pergunta encerrada
No video, no audio, but lights and sound
I have been using my macbook for about 3 years. No problems. One time the LCD hinge broke but I fixed that myself after ordering the part...basically had to take every part of the macbook apart... fun stuff actually!
I say all that to say I am 100% comfortable working inside my macbook.
Having said all of that, my macbook fell off a bedside table onto my bedroom floor... I think the back left corner hit first.
It was on at the time.
Video went dead after that.
Now, when I turn it on, you hear all the gears moving, but where you typically hear the startup tones, you hear nothing.
And, no video.
But the status light stays lit up.
Any suggestions?
Sorry if this is in the wrong group. Please suggest another one and I will happily move it.
thanks in advance
J
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Reseated HD and RAM. Tested each invididual RAM stick in each slot in case a slot or a stick was bad... no dice.
WIll have to find a VGA adapter for this macbook since it doesnt have VGA.
...and what if i cant find my install disk...? :(
por
Adicionar um comentário
2 respostas
Solução escolhida
Reseat the RAM
it could have jumped out of the sockets... If thats not it Boot from your install disk and run Tools->Disk Utility->Disk First Aid->Repair disk.
If this answer was helpful please remember to mark it accepted.
Good Luck,
N
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Hook it up to an external monitor to check the display package. You can also start it up it Target Mode using another Mac. Start up holding down the "T" key and have it plugged into another mac via a firewire cable. The hard drive icon should appear on the other mac and you can run disk utilities on it.
Pontuação 2
1 comentário:
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,818
