Ir para o conteúdo principal
My systems system is slow, takes time to booth, and hangs indefinitely
Macbok Air 13" Mid 2012 Repair
Whenever I put my system on it takes time to boot, usually shows the beach ball repeatedly for long when in the middle of operations. I don't know what might be the cause, I need help.
Esta é uma boa pergunta?
Pontuação 1
3 comentários
How much free space do you have on your drive?
por
Total space is 121.33GB, 83.11GB Used, 37.88GB Free
por
That's getting tight! The smaller SSD drives need at least 1/3 of the space empty for swap & virtual RAM (depending on the app).
por
Adicionar um comentário
2 respostas
Solução escolhida
With SSD's free space is also needed so the drive evenly wears.
At this point I would recommend you create a bootable USB thumb drive so you can boot up under it to run Disk Utility - Disk First Aid. Let's see what it tells us. If you still have Mavericks run repair permissions and then repair disk.
Esta resposta foi útil?
Pontuação 2
In addition to running to using the Disk Utility (which you can also run in recovery mode - hold down Command + R when powering on and wait until you see the Apple logo before releasing the keys)
I wouls also suggest doing a PRAM reset as the the System Manager table may be a little corrupted. To do this, press the Option-Command-P-R and Power button and hold until you hear the boot fanfare 3 time and then release all the keys. Your MBA will rediscover the hardware and create a new boot table.
Pontuação 0
Adicionar a sua resposta
Joseph será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 169
