Ir para o conteúdo principal
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
guide for replacing LCD screen
I cannot find a guide for replacing the LCD screen on 17" unibody.
Esta é uma boa pergunta?
Pontuação -1
1 comentário
It did help but the screw location on the 17" is not the same so I have two screws securing the LCD that are not accessible without more information.
por
Adicionar um comentário
2 respostas
Solução escolhida
This GUIDE for the 15" model should suit you fine. It's basically the same thing.
Esta resposta foi útil?
Pontuação 4
1 comentário:
The screws for the 17-inch Macbook Pro Unibody are underneath the bottom two corners of the assembly, under the rubber "gasket" if you will. If you take your fingernail, you can peel back the rubber about an inch from the corner of the LCD (an inch towards where it would say "Macbook Pro" if the glass was still attached).
Trevor - [URL|http://www.CrackedMacScreen.com]
Pontuação 4
2 comentários:
hey trevor, wanted to thank you for giving that bit of info, never would have guessed apple hid the LCD screws behind there.
por
If i saw this first i wold know where the screws... %%** lol
por
Adicionar a sua resposta
Martin Lee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 1,760
