Ir para o conteúdo principal
A smartphone by Nokia, successor to the Lumia 610, one of the first phones to run Windows Phone 8.
7 Perguntas Visualizar todos
Pergunta encerrada
Digitizer is damage Lcd appearance is there
i have observed that digitizer has been damage though the LCD seems to be ok.
in such situation what need to be change?
please let me know what are the systems for bad digitizer and bad LCD
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It depends how much you want to spend. You only need to replace the digitizer + glass. This will require careful separation between the glass and the LCD. If done improperly you can risk cracking / damaging the LCD. If you want to play it safe, you can get LCD + Digitizer + Frame for $20-$30 more.
You can get the part for just digitizer + glass + screen adhesive from here: http://www.ebay.com.au/itm/New-Nokia-Lum...
If the LCD does not display any more, then the LCD has gone bad too which means you will need to order at least the digitizer and the LCD.
Esta resposta foi útil?
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 10
Duração total: 75
