Ir para o conteúdo principal
The Samsung Gear S, model number SM-R750, is a smart watch which pairs with your Android smart phone. The Samsung Gear S was released in October 2014.
42 Perguntas Visualizar todos
Microphone not picking up sound
My Gear S microphone is not working
Everything else works great
I have reset the watch back to factory ...still didn't work
I have removed the microphone and reconnected it... still didn't work
I used the voice memo app to record and when i hit playback recording i hear crackling noise.
so i am pretty sure the microphone is bad
however i can not find the part number or the part and samsung is no help at all
any suggestions or if someone knows where i can buy the mic would be greatly appreciated
many thanks in advance
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
HI , im just going through the same process at the minute with mine, i have found a company in Holland that can supply me with a new mic, so ill keep you informed.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Use a needle to clean out the whole and it will work fine
por
Adicionar a sua resposta
mickey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 425
