Blue screen and not solve changing home cable
Hi
today i started to open my iPhone 5s to remove the battery and test it in another iPhone 5s, when i was opening, my home cable get out, without the gentile way.
After this, my phone started to show blue screen,
work for 1-2 minutes and blue screen, reboot, all again.
i tried to:
Reinstall iOS.
Change home button.
Change the main screen (with all camera, flat and button)
i DO NOT replaced the wrong screw on the wrong place and damaged the board.
i think it`s about home button, but, after change (for another one), it still having blue screen.
it can be the conector on the board/dock conector damaged?
Esta é uma boa pergunta?
Try unplugging the charging dock cable then try turning it on. If it still turns on fine then you need to replace the charging dock assembly.
por Ben
Can i turn on without charging dock? i`ll try
por freitasgabarrus
I tried to turn it on without charging dock, blue screen again...
what can i try more? battery?
por freitasgabarrus
I think this is board damage unfortunately. Probably a component chip shorted.
Apple logo then blue screen
This is what one of the users said, which is beyond my skill level:
- First change U2 IC and check if working
- Check backlight IC if same
- Then check and replace power ic if problem not solved
- Then most likely fault in processor or emmc now check these
por Ben
i think its a board damage too =/ but its strange that he work for a while, sometimes 3min sometimes 30 min and blue screen and reboot, this made me hope that can be iOS, i will try downgrade version.
por freitasgabarrus
Exibir mais 1 comentário
