Ir para o conteúdo principal
Released in 2007, this version of the A205 series includes an Intel Core 2 Duo T5300, 1GB of RAM, a 160GB hard drive, and a basic DVD burner.
5 Perguntas Visualizar todos
laptop freezes when charger is connected
Hello everyone....
My problem when I connect the charger and windows 7 was opened ,laptop will work for a few minutes and after that will stop working ...nothing work no mouse,no keyboard... And If I want to close it I cant do that by power buttom just take out battery .....and if laptop closed and adapter connected will not work just leds light work ..and screen is black..please help me
Sorry for my bad english
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Hey @com_mad, I did some research on this issue and the known problems with these Toshiba Satillite laptops is a bad capacitor called NEC/TOKIN Proadlizer. You can replace the capacitor or temporarily use your computer in safe mode.
To replace the capacitor:
http://www.laptoprepairblog.net/toshiba-...
One of the ifixit users @oldturkey03 suggests this
Try this work around, until we can find a permanent fix. In SafeMode Go to control panel--> device manager---> go to processor----> disable one of the two processors --> reboot normally. Or you could try to disable your processor there. see if that will make a difference.
More techniques if none of the above work can be found here:
Freezes whenever AC plugged in
-Let me know if this helps.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
almunzir alhassan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Duração total: 1,396
