When pedaling, the back tire locks.
You start to pedal and it feeels as though you just braked forward. Back tire will not turn as though chain locked up
Esta é uma boa pergunta?
Sounds like you may have a bad set of bearings. You will need to:
You are done! Congratulations.
Esta resposta foi útil?
URGENT HELP NEEDED PLEASE!! Hi, Im trying to reinstall a coaster wheel with the same problem,its not the bearings as the wheel was rotating forward before i took out of the frame to fix a puncture,have i maybe overtightend axle bolts (could this affect cone nuts?) or not tightened/secured brake arm enough/properly? Im a coaster brake newbie mechanic wise and its the first time ive put a coster wheel back on so would be really grateful for any advice. thanks Steve
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 48
Duração total: 18,684
1 comentário
when i pedal forward my chain or my back wheel wont move
por ZKWeapons
