Battery not charging unless screen is open after screen replacement
Good day,
I replaced the front screen on this iphone 6 and it will not charge when the screen is on, when I open the phone (not taking the screen totally off) it charges like a hot darn. The minute I close it, no charging. What did I do wrong here?
Esta é uma boa pergunta?
It will charge if I have the screen on but only if the right hand corner is not pushed down.
por Bev
put a new screen on now it works, anyone know why this would happen?
por Bev
Which right hand corner? Top / bottom / middle?
por Ben
Right hand bottom part of screen, never had this happen before!
por Bev
It amazes me how there isn't really a solution to this issue yet as far as I've checked on google. You're not the only one with this issue. Had a few recently that have complained about this. I think it's some sort of grounding issue under the charging dock assembly.
I guess the front display frame was badly made or something for the screen you had before?
por Ben
Exibir mais 4 comentários
