CB not transmitting or receiving very far and is intermitent
CB not transmitting or receiving very far and is intermittent . All settings seem to be fine, aerial is only 12 months old. Connections seem fine. Any chance you could suggest a remedy or fix please?
Esta é uma boa pergunta?
I got same but when I first set up its was brilliant my set up is in the car, with a ranger rig and I have a 100 watt amp and basically brand new mag mount, as said brilliant at first but it’s been getting worse as time goes by. Thou what a nightmare from start things going wrong like power supply failing so sorted better connections then coax with the rig to amp then mic problems with coming away at plug. But now all ok except this signal both inner and outer.
I’ve checked everywhere but nothing wrong, even my swr is checking out at hardly nothing showing right at the lowest possible. Cant work it out, all I can think of is it’s the mic not the best , not sure
por dekingtut
