Ir para o conteúdo principal
Model A1051 / 4 or 6 GB hard drive
20 Perguntas Visualizar todos
Can battery be charged outside of case?
Looking to be able to charge my spare Mini batteries using a portable Li On charger. Is this possible? I am repairing ipod minis as a hobby and I have several batteries that I want to charge before I install them! Is this possible?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Single cells can be charged using a regulated power supply set to a voltage of 4.2 V, and a current limit appropriate to the size of the cell you'd want to charge, say about 0.5C - which means, if your cell has a capacity of 1000mAh you'd set the current limit at 500mA. A seasoned electronics engineer could slap together such a circuit from parts in the junk drawer. Carefully check that the voltage doesn't drift upwards as the circuit warms up under load, and adjust accordingly if it does.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Steve Barthel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 270
