Ir para o conteúdo principal
Apple released the slimmed-down, buffed up iPad Air on November 1, 2013 in a choice of Space Gray or Silver. It packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
Right antenna damaged during screen replacement
I damaged the right antenna (right side of the home button) during screen replacement. Is this part available? How will the ipad function with it damaged?
Update (05/01/2016)
Its the wifi version. I did find the part on Amazon, expect to get it in a day or two and will install and test out my repair.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
I have this problem as well, but mine is the LTE model. Do I still need to get the GPS Antenna Flex? Or is the right antenna a different part on the LTE model?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Is you model the LTE or WiFi?
What is the extent of the damage? Have you completely severed the cable? Post pictures if you can.
As to whither or not it will still function, it might, the iPad has two combi WiFi/Bluetooth antenna, but it might not have the range it had.
Esta resposta foi útil?
Pontuação 2
Yes the antenna is replaceable.
You have damaged the "GPS Antenna Flex".
Pontuação 0
1 comentário:
What is the part number for this?
por
Adicionar a sua resposta
Andrew Curtis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 502
