Ir para o conteúdo principal
The HP Pavilion dv9000 series was introduced in 2006.
51 Perguntas Visualizar todos
Operating System Not found
I get the Operating System not found when I try to boot up. Everyonce in a while it works fine. Prior to getting this error (the last time it worked) I rcvd a DVD not found error.
Any ideas? Could it be just replacing the DVD player?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Sometimes a defective CD/DVD can cause system problems.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
This THREAD helped me when I was having boot issues. Good Luck.
Esta resposta foi útil?
Pontuação 1
1 comentário:
That works for Windows 7 -- here is a add on for XP. +
http://support.microsoft.com/kb/315222
por
It's possible the hard drive is failing.
Try reconnecting the hard drive first. If it doesn't help, try replacing the hard drive.
HP Pavilion dv9000 laptop. Removing hard drive, memory, wireless card, keyboard.
Pontuação 0
1 comentário:
pxe-mof:exiting nvidia boot agent
pxe-e61:media test failure, check cable
por
Adicionar a sua resposta
Steve será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 4,933
