Ir para o conteúdo principal
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
Bootloop + no pc connection usb
Hey!
After trying to install a custom rom to my nexus 7 it just get's in boot loop. I was then gonna reset it to factory rom. 5.1.1 and while doing "fastboot -w update image-nakasi-jdq39.zip" the USB cable accidently got ripped out while updating. So everything lost connection and now i am stucked with a boot loop on google logo and I cana not get into the nexus 7 via USB. I get that the device is connected but not under the My PC folder.
As you can see in this image: https://gyazo.com/be5546434bcc99c9705bdd...
Hope some1 can help me.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
So have you tried going into bootloader and flashing the file again via ADB or does that not work?
Esta resposta foi útil?
Pontuação 0
my did this,,
press on button at the sametime press volume down button.
use volume to select bottom option.
now press power button and volume up button.
on the screen press volume to select factory reset.
mine is now sorted
Pontuação 0
Adicionar a sua resposta
tommyfandersson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 280
