Ir para o conteúdo principal
Released in 2006, identified by model number PP20L for e1505
Why wont power on after changing cmos battery?
why wont my dell 6400 wont power on? I had remove and replaced the cmos battery, so as to reset the bios admin. password and tried to power on and it wouldnt. i have done almost everything except replacing the main battery, even though it doesnt power on with just the ac power either. what can i do next barring the replacement of the motherboard ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Flip the battery upside down. You might have put it in wrong. Or maybe you put in the wrong size.
Esta resposta foi útil?
Pontuação 1
double check the connectors make sure they are connected very well and all in proper place..
Pontuação 0
Adicionar a sua resposta
natassa gletten será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 318
