Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 Perguntas Visualizar todos
I recently replaced the cracked screen
I recently replaced the cracked screen. I tested it before I sealed it and it worked fine. Well after I sealed it then turned it on we got grey white swirls in the background. Did I damage the cable when I sealed it?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It sounds like you may have damaged the LCD connector or cable, you'll have to reopen the unit and check the cable going from the LCD to the motherboard.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Teresa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 59
