Ir para o conteúdo principal
HP Envy TouchSmart 15, model 15t - j000. Release year 2013.
How do I replace the keyboard?
I'm a complete hardware repair novice but I figure replacing the keyboard will be a pretty straight forward repair and it seems this computer is well documented on here so if someone could post a link to maybe a generic guide or give me some pointers it would be greatly appreciated :)
Thank you so much, this website is amazing!
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
I'm not sure about the TouchSmart, but HP has a service manual for the Envy 15 with keyboard removal instructions starting on the page labeled 53, which is page 61 in the pdf document, I think this youtube video guide might be helpful as well. Hopefully those are close enough for your model. You can also check out the guides on the device page, they can at least get you started. Good luck!
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you! Exactly what I was hoping for!
por
Adicionar a sua resposta
Ilmu Kalm será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 1,252
