Ir para o conteúdo principal
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Why does my iPod say very low Battery?
So i have replaced the battery and the hard drive to a photo drive. My ipod wont hold a charge at all now and i dont know why or what the problem could be. it says "please wait very low battery" and it has been on charge for several hours. it showes a battery with a circle and a slash threw it.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
2 respostas
Solução escolhida
Hi Mallory
Assuming that your new battery is good and is connected properly you may need to put your iPod into disk mode, https://support.apple.com/en-us/HT201544 , then connect it to a wall charger. This can sometimes fix this issue. If it doesn't you may want to double check the batteries connection just to make sure it is seated properly.
Esta resposta foi útil?
Pontuação 5
This also happened to me, I had not fully inserted the ribbon to the new memory.
Pontuação 1
Adicionar a sua resposta
mallory será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 19,743
