Ir para o conteúdo principal
MacBook Pro models with a 15" display
8256 Perguntas Visualizar todos
How do I fix a sticky space bar
i recently spilled cola on my keyboard and the space bar seems to be sticking or not bouncing back as fast as i used to i was wondering if i would need to remove the key and clean under it or would i have to go to the apple store to fix it
also i don't know how to remove keys from the keyboard i would need some advice on that thank you.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Solução escolhida
Here's a YouTube video that should help:
How to remove and clean Macbook Pro keyboard keys
https://www.youtube.com/watch?v=LCT-CldP...
Good luck!
Esta resposta foi útil?
Pontuação 2
I recently ran into this myself... sticky space-bar. I pulled off the key and cleaned up all the junk from 8+ years of use, but reassembly didn't help (in fact made it worse).
I ended up using some spray lube on the metal bars (after some trial and error). Seems all better now.
Pontuação 1
1 comentário:
Wow another victory for Tri Flow lubricant.
My space bar was getting a bit sticky and making things slowwwww.
On my almost 10 year old early 2008 Macbook Pro (Penryn), I couldn't figure out anything to do after replacing the spacebar with newer used version.
So I took you advice and gave it another look and cleaning with the Tri Flow lubricant on the metal bars and well, there ya go, better.
por
Ehm, here's a tip. Next time, be more cautious. DONT &&^&^$^ DRINK COKE
Pontuação 0
1 comentário:
Man. If only they would have thought of that sooner. Shucks scoobs.
por
didn't work please help!@45334543534
Pontuação 0
Adicionar a sua resposta
Kat Wardlaw será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 26
Duração total: 46,684
