Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
No LED or charge or power from power adapter
Hi All,
I have been searching for answers and also read through other people posts. Firstly, I am currently in Burma for next 5 months and no Apple shops around here. I only had this macbook for 3 months.
So the problem started when MagSafe looks loose when attached to the dc-in. Like i have to move a little bit or press it. After 4 days later, its completely dead. No LED or anything at all. I have cleaned both sides of magsafe with cottons and doesn't help.
It would be really helpful if I can troubleshoot myself which part is really broken. Example, testing the voltage of the power adapter or if there is any defect with dc-in adapter.. I can easily order dc-in from Singapore but I kinda want to make sure that is the problem.
Lastly, I am not impressed with Apple having power issues on these expensive laptops.
Thanks in advanced.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
You may still be under warranty. I'd contact Apple here: http://www.apple.com/support/contact/pho...
Do you get a light on the Adapter when it's plugged in?
Esta resposta foi útil?
Pontuação 2
3 comentários:
"No LED or anything at all."
por
Worth a try. +
por
No light when plugged in. Not even for one sec. Tried to move the plug around a little bit but doesn't help.
No service center in Burma. Only way is to send to Singapore. But I don't think any apple store do international shipping :(
por
Likely the Left i/o board.
Pontuação 1
Adicionar a sua resposta
diego será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 2,565
