Ir para o conteúdo principal
Controle PS4 modelo CUH-ZCT1. Lançado em novembro de 2013 pela Sony Computer Entertainment, este controlador de seis eixos com bateria de íon de lítio de 3,7 V é simples de reparar. (NOTA: O guia de desmontagem NÃO é para este modelo)
Why is the R2 button interfering with the left analog stick?
When I press the R2 (right trigger) the left analog stick moves (not physically) to the left. It is interfering directly as I saw it using the DS4windows software to analyze the input data.
What might be the problem? Hardware? Software?
Esta é uma boa pergunta?
Pontuação 6
8 comentários
i have never seen this but
it would most likely be hardware as ps3 controllers had issues like this
por
i have this same problem except my left stick goes up, and also when im holding up on left stick the levels bounce from 50-75% basically spamming up.
por
i have this same problem when pressing my right trigger it adds an imput on my left stick to go up even tho the stick isnt moving when i do move the stick it will kinda fight between the inputs this is on a aftermarket xbox one controller that i uses on windows
por
I have a problem with my ps4 controller where when I play minecraft if I press r2 it starts drifting looking left and it is annoying I tried a hard reset on the controller, also set settings to default and and done the hold down analog for 30sec trick but it does not work so can I confirm it is a hardware problem and if so what part should I fix
por
I haven't personally run into this issue, but I could ask some follow-up questions that could help identify the cause.
Were there any recent repairs done just prior to this issue's first appearance? If so, then what?
If this issue just randomly appeared for no reason (and no prior attempts were made) then do you remember any specific circumstances that might somehow be related?
Are there any other strange occurrences with the remote aside from this specific issue -- that you've noticed?
por
Exibir mais 3 comentários
Adicionar um comentário
5 respostas
Pergunta mais útil
Some years passed i see - but maybe someone will use it :)
I had this problem too and it was solved by cleaning potentiometer on X (up and down) axis of Left Stick.
Its a small disk like thingy inside left stick.
This video shows it preety good https://www.youtube.com/watch?v=4AkDIzKq... - however i didnt replaced the part but cleaned it with tissue paper. There was some dirt or rust, i dont know.
However be careful because as told in video you can broke it easily.
It really sound strange but it worked - i cleaned it about 2 weeks ago and the problem vanished :).
Esta resposta foi útil?
Pontuação 3
3 comentários:
Wait isn't the y axis up and down lol? I have a question though, what could you do to temporarily make the problem come /go? My problem is I'm supposed to send the controller into Xbox for a replacement but it doesn't do it all the time it just comes and goes which is extremely annoying and surely to get you killed pretty much every time it happens if you're playing a shooter, so I wish I knew a way to get it stuck like that so I could be sure they would see what the problem is
por
Right On Brother. Sure enough there was a spec of dirt reeking havoc! Had to get inside it to clean it right the first time. Thanks
por
Thx. Cleaning up this potentiometer fixed the referencing R2 to X.
por
Hey, i’ve been expiriencing this issue, if you want it to stop just pull the joystick out, point it to the right and give it a good blow in the hole that appears on the left side
Pontuação 1
For everyone who has commented on this, I can understand your frustration as your controller has failed in some way or another.
You guys can try:
Taking apart the device and reseating the Ribbon cables
Checking the solder connections
Checking the voltage on components related to these devices and actions (Requires multimeterO
The further down this list you go, the more advanced it is. Hope this fixes the issues you are all having otherwise if you haven’t already please contact sony support.
Best wishes from Australia
Pontuação 1
1 comentário:
hardware. the ps4 uses a see through circuit board to register button presses. it could be as simple as buying a new see through board or just cleaning the present one off with some alchohol.
Pontuação 0
I have the same problem except the motion down instead of left or up
Pontuação 0
Adicionar a sua resposta
gabriel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 39
Últimos 30 dias: 166
Ao todo: 43,321
