Why cant I get network on my phone
network comes on and off and its only on in very sensitive areas.
Esta é uma boa pergunta?
• Toggle flight mode on and off
• Switch your phone on and off
• Remove your battery from your phone and then put it back in and turn the phone back on (on if your phone has a removable battery)
• Reset network settings. If you have an Apple iPhone go to Settings > General > Reset > Reset Network Settings
The device needs to be programmed to work with the network.
Under settings > Wireless and Networks > Network operators, check off the network which you have a SIM card for.
Next, go back to the Wireless and Networks page. Select the "Access Point Names" option. Press menu, select "New APN."
At this point you will need to contact the carrier for the appropriate information to enter in this field. Once done, you should be good to go.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 86
