Ir para o conteúdo principal
5 MP camera with 12x optical image stabilized zoom. Released in June 2005
9 Perguntas Visualizar todos
Battery door wont open
Any idea how to get it open seems to be stuck
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Mine wont close. So the camera don not fonction anymore...
por
I have a similar opposit problem. My camera's battery/door wont closed, so the camera do not work at all since. What should i do? I love this camera: Canon PC1310
por
Adicionar um comentário
2 respostas
Solução escolhida
To open the battery door on this camera
  1. Hold the camera upside down with the lens towards you
  2. Slide the LOCK switch to the right and hold
  3. Slide the battery door towards the front of the camera as far as it will go
  4. Flip the battery door open
If the lock switch won't move, it may be stuck due to dirt, or corrosion inside the battery compartment. A drop or two (not more!) of WD-40 might help in getting it moving again.
If the lock switch moves but the battery cover won't, either the locking mechanism is broken and stuck, or the battery cover itself is stuck, the latter is likely due to corrosion in the battery compartment. Apply a few drops of WD-40 around the seam of the battery door, wait a while and see if the battery door will move. Repeat the operation if necessary. Don't force anything. If the battery door still refuses to budge, take the camera in for servicing. Same thing holds if the battery door will open but there's abundant corrosion due to batteries having leaked.
If you succeed in opening the battery door with the aid of WD-40, remove any traces of the latter with a cotton swab and some alcohol: the solvents in the WD-40 may attack the camera's finish.
Esta resposta foi útil?
Pontuação 8
4 comentários:
Thanks soooo much I will give that a try! What would the world be like with Duct Tape and WD-40? :))
por
Believe it or not, I seldom use either. Instead, I use Kontakt 70 and gaffer tape, but these are more difficult to get hold of for non-specialist. :)
por
I got a rubber finger tip from office depot. Cut and Sewed on strap. Great!
por
Thank you so much. I was struggling and you have saved my time and temper.
por
Finger tip from Office Store. Sewed on. Works great.
Pontuação 0
Adicionar a sua resposta
Mark Herman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 8
Últimos 7 dias: 36
Últimos 30 dias: 132
Duração total: 28,141
