Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
20 Perguntas Visualizar todos
Put iMac late 2014 5K LCD on iMac late 2015 5K?
Hello everybody
i am new here
i just broke the LCD of my new Imac 27 late 2015 5K :(
i am unable to use the warranty
so my question is :
the imac 5k late 2014 is using LM270QQ1 SDA2 for LCD
the imac 5k late 2015 is using LM270QQ1 SDB1 for LCD
i know the main difference is late 2015 is using P3 color gamut
but i would like to know if theses two are compatible ?
in other words :
Can i put an Imac 5k late 2014 LCD on my Imac 5k late 2015 ?
does they have the same cables ?
i would like to do that because the LCD from 2014 is less expensive...
Thanks for your answer
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Apple lists them as the same part number - 661-00200 iMac 27" LCD Panel and Glass Assembly, Late 2014 / Mid 2015. Review the compatibility section to be sure your system is listed.
Esta resposta foi útil?
Pontuação 3
9 comentários:
Mine is LATE 2015 not mid 2015
por
Sorry don't have an answer here for the newer model. Have you tried asking Apple for the bench rate for repairing this system? It might be worth it.
por
no, but i assume it would be over 500 euros, so too expensive
i know both lcd are 5k , both are using the same cables
i am just scare about the P3 color gamut thing
thanks anyway
por
It might not be that high, can't hurt to call or visit an Apple Store to ask :-)
por
you are right, i will call
por
Exibir mais 4 comentários
Adicionar a sua resposta
Fanny Augier será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 7
Duração total: 2,126
