Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
stuck on boot loop with broken home
someone help me.
I can't access any nearby apple stores for a while. I have an iPhone 5s that i bought used from a friend, the home button does not work and the power button slowly stopped working except on certain angles. My phone died and when I charged it, it got stuck on the Apple Logo, and I cant turn it into DFU mode , I tried downloading 3rd party apps to make it DFU but none of them recognize my iphone. Itunes recognized it at first but I may have clicked no to a warning at first, i forget what it read, but it doesnt work on ANY of my computers with ANY of the cords. HELP!!! I NEED THE PHONE!!! It's stuck in the apple sign and nothing recognizes it...
Also I doubt apple would give me a replacement because the home button has been broken internally. :/
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Derek
Can you replace the home button?
If you do replace it you can restore your iphone and it is going to work just fine.
After replacing the home button, plug cable to your computer hold the home button and plug the cable to the phone. Hold the home button until you see the iTunes logo saying connect to iTunes then iTunes will ask you to restore the phone and after the restore is done you can start using your phone.
Good luck
Esta resposta foi útil?
Pontuação 1
7 comentários:
sadly the home button is broken internally.
por
What you mean internally can you show me photo. You can replace the whole home button also you can replace the charging port, where the home button connect.
por
The part connecting the home button to the phone snapped, ill post a photo tommorow
por
On another note, is there a reason that the iOS crashes? I mean, i didnt do anything different, it was working just fine, but it just died and stopped working.
por
It is software there is no reason to crash, but they do.
por
Exibir mais 2 comentários
Smart devices are still new to me.
Have you tried removing the battery while the device is on?
Also there should be a procedure to reboot at a default level. I don't remember the correct terminology.
You obviously can access the internet...so search on line for the factory-default-reboot or root-boot, something. It involves depressing more than just the power button at initial power-up.
Hope this directs you towards a solution and not the pollution.
QUIT DRINKING FROM PLASTIC BOTTLES...water, pop, juice....It is killing you and our planet. Well if it kills our planet then it is safe to presume, (well unsafe) that humans will be dead before earth is.
Pontuação -2
2 comentários:
ill try it tommorow... i may have done it before but theres a chance that i haven't done it yet, hope it works. I think removing the battery will make the device turn on still as long as it is attached to a charger, should I unplug the charger maybe?
por
What do you mean by:
'QUIT DRINKING FROM PLASTIC BOTTLES...water, pop, juice....It is killing you and our planet. Well if it kills our planet then it is safe to presume, (well unsafe) that humans will be dead before earth is.'
This is totally irrelevant to the question.
por
Adicionar a sua resposta
Derek Shue será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 4,456
