Ir para o conteúdo principal
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202 Perguntas Visualizar todos
Sim card not recognized after taking off rear cover
I removed the rear case of my HTC one m8 and replaced the charging board as it was damaged. After reassembly the phone works perfectly with the exception of the sim card not being recognized. I have tried inserting it many times as well as putting tape on the card to make it thicker. Nothing has worked. Please help quickly!
Thanks
Esta é uma boa pergunta?
Pontuação 0
3 comentários
I did try that. I disconnected the ribbon cable connecting the sim reader to the daughterboard and then reconnected it to no effect.
por
Did you take out the sim card slot before getting off the back cover of the phone?
por
Yes i did. I also just did a factory reset but it didn't fix it
por
Adicionar um comentário
1 resposta
Solução escolhida
I'm quite surprised to how you managed to make the sim card slot not working properly. Anyway open up the phone again. You may have loosened a cable at the top right of the phone. It's a clip that connects to the sim card slot. Lift up the clip and get the cable out, then plug it back into the clip connector. Try the sim card again and see if it works.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Austin P será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 211
