Ir para o conteúdo principal
The Kyros MID7024 is an android tablet released in April of 2011.
Why does my screen go dark so quickly?
My tablet screen goes blank after a few seconds, why does it do that and how do I change it?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
The screen will often go dark from inactivity but you can also adjust the brightness settings according to your preference.
Esta resposta foi útil?
Pontuação 3
The screen may go dark faster than desired if the device is in a power save mode. Check the device settings to see if this is the case. If this does not help, check the device settings to see if it allows the user to select the amount of time that can pass before the screen goes dim/dark.
Pontuação 2
3 comentários:
How do you change the amount of time it takes before the screen goes darkness
por
I wish I knew!
por
Hi there! I don't know if this still helps, but maybe check your settings, and search for power settings in the settings search tab. You might get the screen time preference under that.
por
Instead of I phone users offering advice, why doesn’t APPLE provide a solution?
Pontuação 0
1 comentário:
A “score”?! I need an answer, this isn’t a game.
por
Adicionar a sua resposta
Kyle Williams será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 6,282
