Ir para o conteúdo principal
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
After replacing my screen I have had ghosting problems
So several months ago I had dropped my onePlus one and cracked my screen loosing all touch capabilities on the bottom 2/3 of the screen. After getting by using a microUSB mouse I decided the best solution for me was to fixit my self thanks to this website. I was able to successfully replace the screen and didn't have any problems with my phone for several months. However, over the past 2 months it has began to have a very annoying Ghosting problem that seems to come and go but has gotten bad enough I have had to apologize for phone calls I didn't make and delete pictures I didn't take. From my research and experience on the issue I'm still uncertain if this is a hardware or software issue. It does seem to be worse if my phone is hot from intense use or very visually intense apps but that is the only clear connection I have seen. Any advice on how to resolve or troubleshoot the issue is welcome and appreciated. Thanks for you help.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
I have the same issue, But i want to try replacing the screen again this time with frame replacement.
por
Adicionar um comentário
1 resposta
Had and still have the same problem, certain cause for this is that screen replacement is glued to the midframe, unlike the original one which is double-taped.. as you said, heat does play a strong factor considering it heats and evaporates the glue causing these touch sensitivity problems.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ChemE TechE será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Ao todo: 155
