Ir para o conteúdo principal
Esta iteração da série Kindle Paperwhite da Amazon foi lançada em 30 de junho de 2015. O Kindle Paperwhite 3ª geração é um tablet com tela de leitura de 300 PPI de 6 polegadas com Wi-Fi. O número do modelo designado é DP75SDI.
20 Perguntas Visualizar todos
Why is my battery life draining so fast?
I’m using my Kindle to read for only a few hours a day and the battery life is always low. Why is this happening? Is something wrong with my battery or Kindle?
Esta é uma boa pergunta?
Pontuação 8
1 comentário
My Kindle is only 7months old but the battery is running low after a single day reading. Really baffled and disappointed. Is this normal ?
por
Adicionar um comentário
2 respostas
Solução escolhida
That is a common problem that happens. Good question!
You may not be using the optimum settings on your device. It is recommended that you set the Brightness to 10 and turn on Airplane Mode when the Wi-Fi is not being used. While this will extend the battery life, it is also dependent on how long you use the device for each day.
If you are still experiencing battery life problems, you may indeed have a faulty battery. In this case, you may need to replace your battery.
Esta resposta foi útil?
Pontuação 8
3 comentários:
Please tell me where I can get a new battery.
por
Where can I buy the new battery?
por
It happened to me also after firmware update in March 2016. It is a bug in the version 5.7.2.1 - something with indexing books. Fixed with manual download a install version 5.7.3.
Pontuação 1
Adicionar a sua resposta
Micah Smart será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 74,494
