Ir para o conteúdo principal
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 Perguntas Visualizar todos
Broken LCD and screen, digitizer ok
I cracked the screen on my phone recently went about trying to fix it myself. I am kind of short on cash so I tried replacing the screen only and not the lcd. When I tried separating the screen from the lcd, the dark glass part remained on the broken screen and the light grey bit remained behind. I was just wondering if there was a lesse expensive way to repair the phone without having to replace the entire front assembly.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Its galaxy S5 !!! You need a lot of work to separate the upper glass from LCD and a lot more work you separate LCD from the frame !!! Just buy a full glass-LCD-frame replacement
Esta resposta foi útil?
Pontuação 0
1 comentário:
You broke your LCD anyway !!
por
Here is the video showing how to replace only the s5 glass: https://www.youtube.com/watch?v=PfJ2ap2p... . It seems a little bit complex and ask for the professional skills and repair equipment. It may be difficult for a DIY repair work, and you'd better replace the whole screen including the lcd screen and touchscreen and the front glass.
Pontuação 0
Adicionar a sua resposta
ryan bob será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 361
