Ir para o conteúdo principal
Announced on September 9, 2015, the iPad Mini 4 maintains the power of an iPad Air 2 in a smaller form factor.
171 Perguntas Visualizar todos
Using iPad mini 3 glass on iPad mini 4 repair?
What it be possible to purchase the iPad 3 glass replacement, remove the digitizer, and use it to replace just the glass on an iPad 4?
Obviously this would be a bit of a hack job. But could it work??
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta Mais Útil
No. 20 characterssss
Esta resposta foi útil?
Pontuação 2
This would be such a difficult repair, one removing that glass from the iPad 4 screen would be nearly impossible with out some very expensive tools to prevent the LCD from damage, during the glass removal and then removing the glue. If for some crazy chance you do get the glass off then just purchase the glass for the iPad 4 and you would be all set. Good luck!!!
Pontuação 0
Adicionar a sua resposta
jjj será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 188
