Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
scratch on the screen
Yesterday in the course of replacing the hard drive, I hurt the black paint (black box) on the inner side of the screen when cutting. Does anyone know how to repair it? Some paint? Scratches are at the bottom of the screen.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Sadly there is no means to touchup the paint as you cut into the seam between the cover glass (which is painted) and the LCD panel.
Apple fuses the two together so dust or dirt does not collect between the glass plates. You would need to finish cutting around the cover glass clean it off and then repaint it. The rub here is you'll end up making a much bigger mess and you'll more than likely break cover glass or damage the LCD which would mean you'd end up replacing the complete assembly which would be quite expensive!
Bottom line here: Leave it alone! As you'll end up making a more expensive repair out of this!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
John será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,586
