Ir para o conteúdo principal
Parte da série Lenovo G de notebooks básicos lançados em novembro de 2012.
My machine won't regulate processor thermal heat
Hi i'm Leslie,
Ive got a lenovo g580, i3 with 8GB RAM running on Windows 10 (v1511) ,
my main problem is the Processor Thermal.
I tested my machine with the Intel Processor Diagnostic Tool 64bit latest version, managed to pass everything else but failed with the following error :
Entering run forever
1 degrees C below maximum
Test Result - FAIL
Expected Greater than 1 degrees below max
Received 1 degrees below max
Test FAILED
Please check your Processor Thermal Solution
Kindly help us with a solution for the problem because its been making my machine shut down unsuspectedly without notifying. This has caused instability when i'm working throughout the day.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Is the CPU fan running? Are the vents clear and unobstructed? Use Task Manager to see what % the CPU is running at. If high % and you are not doing much on the laptop, check what applications or processes are using the CPU the most and why
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Leslie será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 544
