Ir para o conteúdo principal
Likelihood of ultraonic cleaner + isopropanol fixing water damage?
If I have a water damaged iPhone 6 which isn't turning on due to water damage, what is the likelihood that putting it in an ultrasonic cleaner with 99.9% isopropanol will fix it?
Out of ten, roughly, how many would it fix?
And what's the recommended amount of time to leave it in the Ultra sonic cleaner for?
Thanks
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi john to answer your question is the ultrasonic cleaner and I am talking the $100 versions for me it works 7 out of 10 times and I set mine on for about 5 to ten minutes but I use electronic cleaning solution and my mixture is about 4% cleaner and 96% distilled water but with the alcohol solution I am going to be honest and say I don't know. The stuff I use is industrial so you have to contact the company to get it but here is the link http://www.echemproducts.com/ultrasonic-... now for the ultrasonic cleaner this is what I use and your getting a better deal than I did for $76 instead of a $100 https://www.pce-instruments.com/us/index.... Here is the cleaning solution you can easily get your hands on http://www.all-spec.com/products/635-022...
Esta resposta foi útil?
Pontuação 5
7 comentários:
Please add a brand name and link to ultrasonic and cleaner solution.
por
I will try to find a not so industrial cleaning solution to for you guys and I am truly grateful mayer that with that comment you helped me improve the way I answer questions.
por
@meepfish1 Answering questions well is a learning process and you get better at it over time. You're doing fine ;-)
por
Thanks @meepfish1 eepfish1! I have this Ultrasonic Cleaner - http://www.amazon.co.uk/Floureon-Ultraso...
Does it seem alright, do you think? And would you assume that 10 minutes is probably a good amount of time for the alcohol method?
Have you had any experience using alcohol?
por
STOP - using alcohol in an ultrasonic would not be a good idea. Think of an open bowl of petrol or gasoline being vibrated and emitting fumes around an electrical ignition source. https://www.youtube.com/watch?v=iWtohHwN...
por
Exibir mais 2 comentários
Adicionar a sua resposta
John Taylor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 285
