Ir para o conteúdo principal
Released June 2012, identified model JS660
Why is the jigsaw not cutting straight?
When I am using my jigsaw it is not cutting straight. I have the angle set at zero but it is still not cutting straight. What should I do?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
First of all you would need to check the materials on which the jigsaw is cutting. There's a circular knob that have different materials and it's photo of it. Second, sometimes the Jigsaw inserted incorrectly. Check the front of the base of the jigsaw and you'll see a black lever. Lift it in order to insert the blade and make sure to insert the blade with the sharp side facing outwards.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Andrew Khouri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 2,043
