Ir para o conteúdo principal
Wi-Fi only version of Apple's 2nd generation iPad Air. Model A1566.
214 Perguntas Visualizar todos
Pergunta encerrada
ipad air 2 wifi, Digitizer FPC connectors needed
I have a ipad air 2 and I'm trying to locate the digitizer FPC connectors on the logic board. There are 2, one is short and one is long. I only need the long one. Any help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Aren't they in the bottom left of the ipad once the LCD is removed?
Esta resposta foi útil?
Pontuação 0
http://www.ebay.ca/itm/Digitizer-Touch-F...
Pontuação 0
Im not familiar with those connectors, but if you simply broke off the long connector clip/tab that secures the ribbon cable, there is easy fix for that.
I have a YouTube Video, "easy ribbon cable connector fix, repair"
Austin_semiconductor
Pontuação 0
1 comentário:
Nope, the Air 2 connector is different.
por
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 282
