Ir para o conteúdo principal
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Perguntas Visualizar todos
27" Late 2013 iMac broken screen replacement (
Sorry my bad English.
i have late 2013 27" iMac with broken screen ( LM270WQ1(SD)(F2) )
One eBay seller write to me that Late 2012 27" LCD panel LM270WQ1(SD)(F1) fits to my mac ?
Esta é uma boa pergunta?
Pontuação 4
2 comentários
This question was migrated from http://meta.ifixit.com/Answers.
por
http://www.displaysscreen.com/index.php
They have the correct item for you.... the cost is about €350 delivery to italy
por
Adicionar um comentário
1 resposta
Solução escolhida
Here's how to replace it: iMac Intel 27" EMC 2639 Display Replacement
Even if you have to pay a bit more, get the correct part to eliminate possible hours or days of hassle. You can also search for these: Part Number: 661-7885, 661-7885-R
You should be able to get it for $500
Ali says it is compatible: http://www.aliexpress.com/item/New-LM270...
There can be minor things such as on this question: LCD panel replacement with different (A2)(C1)(C2)... indexes
Esta resposta foi útil?
Pontuação 6
Adicionar a sua resposta
alariaug será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 34
Duração total: 22,241
