Ir para o conteúdo principal
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
190 Perguntas Visualizar todos
I bought a new battery, but why doesn't my phone work?
My phone will not work. I bought a new battery, and the screen lights up, the red light is on, but I cannot make or receive calls. The volume, answering will work, but won't turn off until I press the buttons.
The screen message is Handset #1New CID:50
Please advise. Thank you.
Perhaps these numbers will help to identify my phone. I've had it for some time, but don't want to replace it.
M/ND1680
IC-513C-UN244
REN.0.0 311E0811
BQ 80685754
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
The red light indicates that the battery is charging. What is the battery display in the phone showing? Have you fully charged the battery?
By replacing the battery you may have removed the 'registration' between the base and the handset.
Try resetting the handset to clear the registration information from the base and the handset.
Press & hold END and # at the same time until you see the System Reset menu.
If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. To confirm, select Yes. The handset displays Handset not registered
If you see a “not registered” message on a handset, you must register it to a base before using it.
Place the handset in the base; the display should say Handset Registering.
Wait until the display says Registration Complete (about 30 seconds), then pick up the handset
and press TALK/FLASH. If you don’t hear a dial tone or the display says Registration Failed, charge the battery completely, then try again.
By the way your phone is probably a Uniden Dect 1680.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Hi
This process doesn’t work for me. I still get registration failed. What should I do?
por
@benhunter87050
Did you try registering the phone by having the phone next to the base station?
por
Adicionar a sua resposta
Mary Lein será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 36
Duração total: 4,338
